Craftex 9 x 19 Lathe Vancouver $2,100
chip4charlie
I am selling my Craftex CT039 Metal Lathe
Same as Grizzly G4000
This is not a mini Lathe
This is a complete setup a 9” Metal Lathe with all it’s accessories , cutting and measuring tools. All you need is metal to start turning
It is currently wired to 110v but can also be wired to 220v. This is one of the largest Lathes you can run on 110v
Capable of carriage feed, metric and standard threading. Capable of turning Steel , brass, aluminum, wood, plastics.
Has reversible 3 jaw Chuck as well as a large 4 jaw independent chuck.
Steady and follow rest included
Has A quick change tool post with 8 Holders ranging from 1/2” to 3/4”
3D printed Holder mounts on top of lathe for fast access. Stock square tool post included.
Live centre, dead centre, 1/2 chuck, Digital dian indicator, indicator Stand, 1/4” and 1/2” Carbide tool bits ( brand new) , Cut off tool (parting tool), 1/2” Boring bar set, micrometer, owners manual, a book to learn Turning on a lathe. Machinist
Carriage Lead screw has custom bellows installed, compound slide has been upgraded to a stronger design clamp ( old clamp included)
Larger Hand wheel for cross slide installed for easier turning.
I have turned accurate parts on this lathe that went inside my motorcycle engine, brakes and many other parts.
Can be taken off stand and loaded in back of many vehicles
