KeeponDragon
no problems... just challenges
I have this "challenge" with wanting to improve or modify things. And it's usually stuff that qualified folks spend months tweaking to ensure it's reliability.
Do I know better then them?
I dont believe so.
So I guess it's a case of "because I can, I will"
My 03' Tundra has almost 370k on it now. No idea how long a thermostatic fan clutch is supposed to go for.
So I spent some time, made a plan, collected parts, made a part, and this weekend, decided to do the install.
My main concern was being able to return it to OE, should my bright idea not be up to task. So far, I've only had to clearance the hub knob on the water pump. Conveniently, I placed the electric fan right in line with the pump. Because Oops.
The coolant temp switch goes in here. I machined this out of a piece of solid stock.
Then welded the bung into it
The electric unit is a little smaller than the belt driven one, but the speed it moves air should be a good offset.
It's a good fit. Tucks in nicely.
I managed to get a 3 or 4 mm gap between the motor n water pump snout.
The main objective here, besides saying I did it, was to free up some of the remaining horsepower this engine still makes...
Guess I'll find out
I dont believe so.
Guess I'll find out
