Canadian Made Lathe...
KeeponDragon
no problems... just challenges
FB marketplace ad
MacGregor Gourlay Co from Galt, Ontario...
price seems steep, but it might be a good one for someone.
I'm confused about the placement of the motor, it looks like it's fixed. But that negates using the other 2 drive hubs doesn't it...
cast base...thing must weigh a bit...
I might be able to go check it out if anyone is interested
Peachland, BC, $2,900
FB marketplace ad
Yes, the motor appears to be fixed in the high speed shiv. Originally this would have been line shaft driven and the speeds were made by moving the belt, but with this conversion they have added a transmission from probably a model T or some such, which gives you the lower speeds.....
Oh ffs ...I thought that was the motor, I only just glanced at it...ok...that makes more sense...
Ive seen that 2 other times with a transmission on a lathe...one looked like an old GM 4 spd top loader...
Neat idea...
