Everything you are saying there makes sense. It is clear that your solution works for you.
The standard for RPCs for lathes has always been 2X - with the newer digital ones many manufacturers are using 1.7X. There are good electrical reasons for these figures, but anyone can use whatever and make it work.
For instance on disk sanders the motor HP always seems too large, and on belt sanders is usually 1HP per inch width of belt -- if the belt is moving over 2000 SFPM. I have a 3/4HP and a 1HP 6X48 belt sanders, and I can use them, but under load they always slow down. The 'correct' size is typically 3HP (both my sanders operate in the 1000SFPM-1500 SFPM range).
You asked why 25HP and gave you the answer. This is an attempt to give you an nontechnical followup, It feels that the above indicates that you might not accept these guidelines, and that is fine. The technical issuses go to capacitor strain, what is an acceptable brownout voltage, and other factors, some of which I'm sure I don't know.
What I do know is that American Rotary makes very good equipment, and their stuff lasts a really long time. If I didn't have a 15HP RPC already I'd have contacted the seller.
