VicHobbyGuy
https://bid.ableauctions.ca/VANCOUVER-ISLAND-ON-SITE-AUCTION_as84587_p7?
Location TBA but looks like up-island?
So possibly ruined for manual work because the leadscrews were replaced with ball-type screws?Lots of cnc and servo stuff. The lathe and mill are servo driven.
I'm not fit to educate anybody about machining but I have read that ball screw mods to lathe cross slides have so little friction that without a stepper motor actng as a 'lock' on the end, the slide won't keep a setting....the weight of a standard handle will turn the screw. When I read that, it sounded like something a gib adjustment would correct, but I don't know.Educate me here. Why would a ball screw ruin manual work vs ACME lead screw? I would have thought that to be an upgrade, particularly when climb milling!
You've got it right.I'm not fit to educate anybody about machining but I have read that ball screw mods to lathe cross slides have so little friction that without a stepper motor actng as a 'lock' on the end, the slide won't keep a setting....the weight of a standard handle will turn the screw. When I read that, it sounded like something a gib adjustment would correct, but I don't know.
I did pose the comment as a question, after all..but that didn't elicit an answer or explanation.
Good to know; thanks...though machines like those are definitely 'out of my league'.This is manual machine with added CNC stuff that is not complete. Machine is fully manual capable from the pictures. Adding actual CNC may take some work.
