A coolant system I built for the bandsaw. Pump is a cheap centifugal 12 volt unit. Filter is a rectulation filter with rare earth magnets in the pipes before the filter. Coolant container is a 5 litre plastic fuel can. Tubing and tap is also reticulation. Tube is split at the end and saddles the cutting blade. I made a rubber gaket to fit under the small table. This has to be changed regualarly to stop coolant spewing out the rear of the machine.
