Gauge Block Set, Setup Blocks, Adjustable Angle V Block 0 - 60 | Hand Tools | City of Toronto | Kijiji Classifieds
Material: steel,surface hardened to HRC58-62 °, nickel plated. Dimensions: approx75 x 25 x 32MM (L x W x H) Uses: In the milling machine, planer, drill press with adjustable angle grinder and regulations on the blade, crossed with other fixtures or clamping the workpiece after the workpiece...
www.kijiji.ca
