Meh. all pretty normal functions. Last shop I was in had all AcuRite except for one Newall (which i was not impressed with, though I think we had a dud), and one high end Japanese unit on the Tool and Cutter grinder (Sony, IIRC). The Acurite's ranged from a brutally simple two axis unit that had only two toggle switches (one to switch between inches and MM, the other to zero each of the two axiis), and an on/off switch, and two LED displays for the measurements, on a surface grinder, ranging up to a four axis capable Milling DRO with a touch Probe option.
The one and only problem we ever had was on a brand new lathe, which the supplier had cheaped out and used a 'not quite long enough' glass scale on, it tore the read head off the reader, at the end of the travel of the cross slide. Took exactly one phone call, and no money, AcuRite sent me a new, inch longer scale, as well as a shipping box for the damaged one to be returned in. Easy!
Like I said, the modern stuff is fine for a home gamer. Maybe even OK for some shops. But I have, as I said thirty to forty year old units that are still running just fine, and for which I can still get support.
We never needed tenths level accuracy in general, but at least we had machinery that was of a quality that it was plausible to expect that it was an option, which I suspect most of the folks that have home grade machine tools, are never going to achieve, let alone twice in a row, generally through a lack of rigidity, or simply that the machines were never actually as straight and aligned as they needed to be, to make working at that level possible. So Micron level measuring is only worth talking about, if the machine it is ON, can actually achieve it. Dan Gelbart covers some of this sort of stuff in a video where he makes a lathe that actually CAN do this every day... Worth watching!
I mean, great talking point and all, but when do you see needing to measure that accurately, and do you honestly believe that your machinery is worth the time and effort?
FWIW, I had, and sold on with a lathe that I sold, a Sino DRO with glass scales. Same basic bells and whistles as what you have. It's cheap enough to add to a software package. Harder to make the Hardware last as long as the useful life of the Machine Tool.
My problem with magnetic scales of any sort, no matter how thin, is that they are affected by any other sources of magnetism, that may be within range. After playing a bit at watch and clock repair, I gained a deep respect for the stuff, as well as the importance of demagnetizing anything that was even vaguely suspected of having picked up a magnetic charge... Your machine tools are full of ferrous metal parts. Ever magnetized a screwdriver, so that screws would stick to it? You stroke it across a magnet. Or expose it to a strong current flow. Do you really think that a magnetic Indicator base, does not leave some traces of magnetism behind when it is removed? Or Moved, esp., while the magnet is on? Very small forces, can have big effects! FWIW, I also have been qualified to do Magnetic Particle Inspections, at one time, long ago. Best advice ever... "Do your bolts in batches of ten, so that when your hands start moving and your mind is asleep, you have a pretty solid idea how far back you need to go to re-do the inspection and actually LOOK at them!"
Anyways, YMMV, but if I have a choice, I will buy a used "Industrial" quality tool at a reduced price, rather than a "New" one, built down to a price point, rather than up to a standard of quality, any time!
