Acu-rite II DRO connector
grizzlychicken
New Member
Hi all!
So I recently purchased a standard modern lathe that came with an acu-rite DRO. Unfortunately the connector pin is melted/crushed.
I’m looking to source a replacement connector.
An ideas where to look?
Shane
Tomc938
I might have one for you. I’m working toward TouchDRO as one of the boards in my unit is toast. When I go Touch DRO I was thinking of changing the ends to a standard plug.
Might have a total unit if you are interested. Other than the one card everything else seems to work as it should.
Where are you located?
grizzlychicken
New Member
Hi Tom,
I’m in Alberta. The rest of the unit seems to work just the plug is the issue.where are you at? Let me know if you are changing your plug
Up!
