$50 2hp VFD - Whitby, On
Dan Dubeau
https://www.facebook.com/marketplace/item/589748386996897/?ref=product_details&referral_code=marketplace_general&referral_story_type=general&tracking={"qid":"-534290357378586159","mf_story_key":"6239696718006125507","top_level_post_id":"6239696718006125507","commerce_rank_obj":"{\"target_id\":6239696718006125507,\"target_type\":6,\"primary_position\":1,\"ranking_signature\":7353976604442009076,\"commerce_channel\":501,\"value\":0.00039425370587014,\"upsell_type\":129,\"candidate_retrieval_source_map\":{\"9163539070427876\":3004,\"9094740413974398\":3099,\"7547084158749412\":3003,\"9032128163572858\":3001,\"9155519491153729\":3012,\"9479214435422514\":3004},\"grouping_info\":null}","lightning_feed_qid":"-535428970147649106","lightning_feed_ranking_signature":"6359473682933408606"}
Check the specs above. This is not a 240v single phase input VFD, it's for 575 3~in/out. Or else I would have been posting about the new VFD I just scored lol.
I posted thinking this would be great for those that have a surface grinder running off a phase converter/transformer/native 600v. This is a perfect and cheap way for you to gain variable speed and softstart capabilities. Might be good for a lathe/mill too.
Part of the reason I did not get a mill in 380v range is b/c getting 1ph 440v to 3ph 440v VFD is difficult.
3ph to 3ph 440v class VFDs are common.
