I bought a Hitachi VFD 3 or 4 years ago - it was more money than some of the others but the manual was in well written English and I trust (hope) that most of the inner components are of a higher grade and will hold up better. IIRC, it is 3 hp rated and I've put it on a 2 hp motor. I over speed the motor at times (90 Hz) which spins the 1740 motor up to about 2600 rpm, at other times, I run it @ 6 Hz which gives me ~180 rpm. When run at ~2600 rpm, I've got to be less aggressive on the ramp up / ramp down on the start / stop or it will trip and I have to re set it. I assume that if I had put a 4 or 5 hp unit on it, I could be more aggressive with those settings (not that I need to, it was just fun to play with those settings). Much more versatile than single phase.
