i am just about to the point of having to make a new draw bolt for my mill. Standard size 7/16 NF like all the rest . Just wondering what rod would be best to use hot rolled or cold?
Others have suggested a steel to use. I'm not going to do that for you but perhaps I can add a perspective.
The low torque used to tighten a drawbar results in a correspondingly low tensile stress in the drawbar that almost any steel can easily handle. If I were making one, I wouldn't be very fussy about the steel I used.
Because a drawbar gets frequently tightened and loosened, I'd be much more concerned about the quality of threads I cut and the resulting fit and wear conditions imposed by repeated use of collets and arbours on poor quality drawbar threads.
Another condition to be aware of and perhaps design around is drawbar rattle. To have the best chance of being rattle free, a drawbar has to be held in the very center of the quill. If it is not centered, centrifugal forces can play havoc on a long spinning shaft. A fairly effective solution is a centering bushing. But this isn't always as simple as it sounds. Many factory drawbars have rolled threads which means the shaft itself is smaller then the OD of the rolled threads. To address this issue, the bushing ID has to be sized to fit the shaft and then inside threaded to fit the shaft threads. The bushing is then installed by threading it over the drawbar threads and then sliding it to the top of the draw bar.
Here is a picture of my bushing. It is inside threaded to fit the drawbar threads and the smaller OD of the collar fits the ID of the top of the quill. The ID of the bushing fits the OD of the drawbar shaft.
Here is the thread I posted about this bushing. Your drawbar might not need to worry about rolled threads, but it is likely that your quill ID is bigger than your Collet threads.in other words, you will still need the bushing but it won't need to be threaded.
How about a grade 8 bolt (or similar strength) welded onto any type of steel rod?
As has been mentioned, it is the threads that take the most abrasion and thus lose form fastest. If they wear out, cut off the bolt and weld a new one on. You’d be back in business right away.
Great replies. My main concern is the condition of the threads . As they are wearing/distorting I'm afraid they are coming close to the point when they may ruin the threads in the collets. I was wondering what steel would provide best service for the draw bar. Cutting the old threads off and welding on a new threaded section is an idea but might be hard to get straight. I may try that. Thanks for all the suggestions! Also, these threads are cut, not rolled. @Susquatch ,so your bushing sits at the top of the spindle, under the bolt head?
Yes. You are lucky to have cut threads on your drawbar. Some do, and some don't.
And yes, the bushing sits at the top of the quill under the head of the drawbar. The small OD fits into the quill taking up the slop, the big OD takes the compression force between the bottom of the drawbar head and the top of the quill, and the ID fits the OD of the Drawbar Shaft. The purpose is to keep the top of the drawbar centered inside the spindle.
If you do the weld suggested by @RobinHood properly, a Grade 8 bolt would certainly make a great threaded portion of a drawbar. I also keep mine oiled.
Mine is manual, and I always wondered ( being very familiar with air tools)how guys avoided over-torqueing these things. I guess you could regulate the air press. I like having the ability to feel how much torque I am applying.
If I needed a draw bar I'm pretty sure I have a few various lengths of 7/16" grade eight Redi rod in my metal pile. A couple custom nuts for the end and good to go.
Ever since @Mcgyver mentioned welding on a section of grade 8 bolt, my mind has been focussed on the idea of finding an existing grade 8 bolt the right length with a long unthreaded shoulder, make a bushing to both center it and raise it up high enough above the spindle.
It would not be cheap as bolts go, but it would cost way less than a brand new drawbar.
A cut thread drawbar on Amazoom is about $32. I'd do it that way rather than trying to weld up a properly aligned drawbar from scrap.
If the 7/16 threads are cut in softer (malleable) material, there is always the option of case hardening followed by a gentle temper. The drawbar I bought has cut threads and is half-hard.
Another option is hydraulic cylinder compression bolts. Might need to pin a head on them or even thread them at the right place, but they would be ideal for the application.
I’ve only given mine a rap with the wrench to loosen mine on the 601. We’ve only had one endmill pull out while my Son was feeding too fast he also was cranking it when the electronic board blew.
