Ironman
I just sold off my Kubota tractor and the tiller, brush hog, and undercutter, etc and bought a Massey 35 tractor so, now I'm upgrading to a larger rotovator, and brush hog, and making a larger undercutter for the garlic harvest. The Massey is a true rowcrop tractor so I don't have to add spools to the rear wheels to get wide enough to straddle the rows. I cut the bits and pieces on the plasma table, bent the arms on the press brake, and then started assembling everything onto the main bar which is 2x2x1/4" tubing.
Somewhere the pictures I took of the assembly and tacking everything into position is in the 4th dimension and therefor unseen. But here is the mess of photos of the rest of the welding and assembly. Along about 1/2 way through the construction, after the cardboard design stage, I decided to get me a quick hitch. Normally if you are frisky and want to wrestle with the 3point, the actual dimensions are very flexible. With a QH you want the top link pin to be in the same vertical line as the bottom arm pins. So I had to add an ear to each side of the top link to make the QH happy. I could have lived with it the way it was, but why should I?
