I got this boring bar holder with my quick change tool post set and have never used it because it only fits 3/4" diameter boring bars and I have none that size. I have a cheap set of boring bars that fit my boring head that has 1/2" holes. I made an adapter sleeve to fit the QCTP holder and hold 1/2" boring bars. I used a chunk of the original Y axis lead screw from my Ferro mill. It is 35mm diameter and large enough to produce the needed 1"OD and 1/2" ID needed.
You can see how worn the old lead screw is in the center.
My goal was .998" OD to match the original sleeve and I hit that dead on.
I used extra long drill bits to make the ID bore .500"
Then I used a slitting saw to make a .040" slit length wise end to end.
A great way to spend a Sunday afternoon.
