Nothing is better than a good puzzle.You are a sick, sick puppy......
They say the same thing about electric shock therapy, but, I am not licking the electric fence...........again.Nothing is better than a good puzzle.
Heh….. Remember checking 9V batteries with the tounge?
Is there another way?I still do that LOL...
Hopefully I understand you correctly… you are saying that if you were to take off the nut (red arrow) , you can not just slide the combo gear off the shaft and turn it around?I looked at that when I originally was trying to turn metric threads and the center hub/bearing assembly would have to be pressed in and out of the gear in order to rotate it because there is a spacer that is part of the assembly. I'm presuming they wouldn't have designed it that way
I'm sure in a short while I will be able to agree with you. But for now, we have a different classification of "fun"...LOLI sure wish we lived closer. I would LOVE to dig into that nasty problem of yours with you. It would be great fun! I know you won't agree for now, but I'm actually jealous of the fun you are having.
That is correct. I tried (very gently, but firmly) and this is a pressed in bearing/spacer assembly. The temptation to put it in my hydraulic press and try was there, but I sat for a moment and decided against it.Hopefully I understand you correctly… you are saying that if you were to take off the nut (red arrow) , you can not just slide the combo gear off the shaft and turn it around?
Have you tried it?
That gear has a 6203-2RS bearing in it. The axle runs through the inner race. The bearing / gear assembly is held to the axle shaft by the retaining nut (red arrow) and a washer. It has to come apart.
On the equivalent Grizzly lathe (G4003 12x36 GH), that gear is flipped around allowing the “F” gear to mesh with the 91T portion of the compound permanently. Tables for this lathe also seem to indicate that F should always mesh with 91T and not 86T as you have it on your lathe.
The diagram picture of the 86/91 compound does not match the nomenclature either (that is true for both the King and the Grizzly models): in both cases the 86T label is associated with the larger portion of the compound gear and the 91T label is closest to the smaller side. I believe that is an error.
The "again" part of this makes me question the "thinking things through" process you use...LOLThey say the same thing about electric shock therapy, but, I am not licking the electric fence...........again.
What can I say, I can lift heavy things.......The "again" part of this makes me question the "thinking things through" process you use...LOL
I've done this. I don't recommend it. You can re-engage in the same groove of the lead screw if you track it well, *BUT* the gears in the headstock make no guarantees to hit the same teeth. So you get a bunch of good passes, and then the backlash is slightly different and you get the wrong tooth somewhere in the gear train and kablooey, you part is trash.yes, however, I watched an interesting video on "ox-tools" YouTube channel last night that has a cool workaround for that. If I knew how to link things I would do that...
Yes, that is the gear. I assure you there are no screws and it definitely is metal...Is this the same gear (122) we are talking about? Weird, it shows 4 counterbores for cap screws? But it does say 86/91 teeth. Nylon???
Loading…
files.kingcanada.com
Sounds like it's time to bend the king over and firmly place his crown where the sun doesn't shine.......SO, an update on threading on my lathe. I had several emails back and forth from King and basically they told me they had sold many of these lathes and had no issues so there is nothing wrong with my lathe...
Apparently, after purchasing a new lathe I still cannot single point thread....
Very disappointed in the response from King.
That's what the discussion with the dealer will be. I waited 3 months to get it when I ordered it. I don't know if they will be willing to do a swap. (at least I have a lathe to use in the mean time...) Like I mentioned, King said they haven't had any issues so there can't be anything wrong with it, so they won't be willing to help at all.Presumably, we buy new to avoid such problems. This puts a whole new light on the situation.
What is involved in returning it?
Is there a ladder to climb there?
