I may have known the full answer at one time but it is now escaping my little pea brain and therfore I must ask...
From what I understand and remember, the pros of a gearhead lathe over a belt driven one has been chalked up as:
No pulley changes as the gearbox usually deals with all speed changes
More positive drive (no belt to slip or break or wear out)
The pros to a belt driven lathe as I understand and remember are:
Belt drive lathes are cheaper to manufacture.
Belt drive can provide a nicer finish as there are not the vibrations/harmonics that can occur with a gearhead lathe.
The downside of a belt driven lathe as I see are the belt changes to get the speed and feed changes.
However doesn't a variable speed motor (DC or AC VFD) on a belt drive pretty much elimate %90 of belt changes while providing an on the go range of speeds in any combination?
But even with a gearhead lathe isn't the geardrive always driven by a belt from the motor anyhow? And if so, why would that offer any advantage?
I know I'm missing something otherwise I'd see not only small lathes being predominantly belt driven.
