Train horns
Let's see a pic of what you have so far.... Put something in the image for size reference.
Dusty
(Bill)
Is it legal for a semi? Wow that will surely rattle their teeth while messing their undies.
francist
I have a few as well, collected over the years. Last time I ran them was for the front line workers salute every evening during the height of COVID onset. Lots of fun.
Chicken lights
Forum Pony Express Driver
Do you run yours individually or set up to run together? My understanding is limited but I believe they sound better in a group? I remember chatting in another thread about them awhile ago
francist
The only ones I sound together are ones on a manifold made for that. So my K-12 (bottom left in my photo) is sounded as two horns together because they’re on the manifold made for that combination, others are singles so I keep them that way even though the individual horns themselves are the same if that makes any sense?
Takes twice the air to run two at a time though, so it can get eaten up fast. I think a lot of people like the sound of a twin or combination horn better than a single as they can have a little more depth or complexity to the note. Kind of like listening to one tuba vs a group, there’d be more depth to the overall sound. I’m not an expert on them though, some of the real railfan guys have made a life’s work out of studying what gets that best sound.
From here yours looks like a die cast K-1? Should sound pretty clean :)
Everett
My boss at work has a Peterbilt highway tractor with two train horns mounted under the cab and an air valve by the driver's seat. It came that way when he bought the truck and let's just say that we don't let that thing blast in the shop!
Swharfin'
Out to pasture Red Seal Millwright
I found a 1/2"ball valve a simple static way to control pitch and Db- it had no issues @ 150 psi full flow ....I did tho
Chicken lights
I need to actually find where the tiny Roadrunner horn is on this truck and figure out how it works. There’s a 1/4” airline running from the pull cord down the A column, I’m guessing that’s a signal airline running to an air valve. On my other truck there was a 1/2” airline running to the air horns, but I didn’t install those that’s how she came
@Brent H gave me a piece of stainless that used to be a shelf, I’m thinking that might get cut to make a mounting bracket
