Ran across this forum while searching for my tapping problem
My vehicle has a plastic drain pan and a plastic drain plug which the oil change shop stripped out. Unfortunately it’s a huge plug M24x1.5, so commonly found oil plug problem solvers are not large enough. However At a truck diesel parts place I found a jumbo sized drain plug solver with a valve to let the oil flow out such that the plug never need be unscrewed. It’s a M27x2
I have no experience tapping holes but assumed plastic would be simple enough.
Question is whether I can successfully put a M27x2 tap into stripped out M24x1.5 hole.
Any and all input is greatly appreciated. I’m currently leaking at least a quart a week... need to fix this. The other alternative I’ve found is tapping a M26 since I did find a steel replacement M26 plug (just a plain plug with no drain thru feature) but if the M27 is too big to tap into the M24 hole then maybe that’s the other route. I’d prefer to install a plug that never moves again that way I won’t have to be so careful about who I let touch my vehicle (it sits very low and has a splash shield so changing my own oil is not the easiest task otherwise I would DIY it) Thank you.
