Spoolmatic gun and WC-3 controller
johnnielsen
John (Makonjohn)
We picked up a new toy today. It`s a well used but functional Spoolmatic gun and WC-3 controller accompanied by 16 1 lb rolls of aluminum mig wire and a bag full of tips and contact tubes. I`ve always wanted one and Dabbler needs one so we split it.
ersatz engineer
Now I don't have to worry about TIGing 2Kg of aluminum filler rod! Assuming I can get the hang of it, it'l save a lot of time and cost.
Brent H
@Dabbler, what machine are you running it off? I run mine off an Everlast MTS 211 si. Inverter type welder. For 0.030 wire I get best results 130 - 145 amps and pushing the weld yields a much cleaner final bead. The gist is to actually “spray” the weld so you will hear a different sound than frying bacon - as with MIG. I welded up my router table fence (1/4” thick) with no problems.
Have fun!
Have fun!
Voltage? Is that steel?
Congrats guys! And we need pictures!
Brent H
@Janger - that was for aluminum- I will have to check the voltage - was a while ago. Weld changes sound when you get to the spray part. My welder has that “synergic” mode so amps and volts work together but it’s the amps you can adjust. I would be guessing at 21- 22 volts. It is a setting I saved in the memory so I can recall it tomorrow off the welder.
