Hi everyone! First post here and i'm excited to get started in the world of machining.
As a note, I'm almost completely green to owning/operating a lathe, but am a quick learner. So forgive some incorrect terminology or flawed explanations.
I recently purchased a Standard Modern 11" 2000 series lathe for my home shop from one of the members here, Darren. Great guy and easy purchase.
Somehow the feed gear shafts key spring/retainer popped out. I ordered new parts which arrived very fast, Welded a little damage in the smaller gear and reassembled.
I've never been in a headstock of a lathe, and couldn't find any good pictures of what all is supposed to be on that feed gear shaft but it seems as if the gears are free to slide along it without any sort of spacer to keep alignment in check. I took a picture from one of the posts on this forum and circled the areas i'm referring to.
So on this feed gear shaft, there is a cluster of gears right at the beginning that remain in place (yellow circle), then a small loose gear, washer, larger loose gear, approximately 1" of space, the support, then the set screwed collar.
Is there supposed to be any additional components here (red arrow)? Just seems as though its all quite free to slide. that first cluster seems to have around 1/4" of play. The larger loose gear is free to contact the support when the shaft is pressed inwards. Maybe this is just how it is and is fine since its in an oil bath.
Long story short i would love any information someone can provide to me.
Cheers
Cheers
