Ok, so I admit I am a newbie, and my idea might be nuts, but I thought I would ask before I give it a whirl...
I have a King RF-30 clone. As I have heard, the Rond column is a drag when it comes to moving the head up and down as the whole thing pivots.
I am wondering if it would be possible to make a Tru-Line-8 type of alignment set up (
), but rather than clamping a large clamp to the bottom of the column, to make a fitting similar to the way the device clamps to the head, but on the base, UNDER the column. It seems that you would need to extend the arm until it is higher than where the column meets the base so you can have the right amount of travel.
This seems to me to be a much simpler way of firming up the head. I realize that this would mean that you could not use the attachment to keep things lined up if you want to rotate the head, but I'm not thinking would be rotating the head that often. Not an option for most milling machines in the first place.
If this description makes sense, and with your experience you can see a reason, or possible reason, why this would not work I would appreciate your thoughts.
If I do go ahead with the project, I would prototype with my 3D printer and make sure everything lines up before going into metal.
Thanks!
Thanks!
