When you’re backing up to a trailer, they help pick up the front of the trailer so it’s not as much of an angle when it meets the 5th wheelWhat are these ramps on your truck used for?
The 5th wheel tilts but if the angle is too steep it won’t tilt to pick up the trailer
I dunno how better to explain that
Eummm couple things there. No, you generally don’t install/remove often. On my other truck they are welded on likely from the factory.Why is weight a factor? Are they something you install/remove on a regular basis?
Between posts like this and "Highway Through Hell," I'm learning more about the trucking industry everyday.Eummm couple things there. No, you generally don’t install/remove often. On my other truck they are welded on likely from the factory.
Other issue is they should be “sacrificial”, if they’re gonna get hooked I’d rather trash the ramps and not the frame rails
For weight- legally 80,000 pounds is considered max in most of North America. If the truck is really heavy then I can’t legally scale some loads
That one trombone load to Texas I grabbed a load of steel that weighed 39,000 pounds roughly. The truck and trailer empty weighed 39,000 pounds. Sure that’s still 78,000 so it worked it’s just an example of why if I have the chance to drop 400 pounds, I’m gonna take it.
You can run half tanks too to shed weight, fuel is roughly 7 pounds a gallon I think
Perfect job for a needle scaler...you can do some cool artistic stuff with them too. Kinda loud, but fun to use. Nice work.Also in the middle picture I broke out my needle scaler. I’ve never used one before, that’s a useful tool.
Yep, white truck, grey truck and my little crewcab longbox F350 grocery getter
But not the trailer or the Uhaul??Well you'll have to include the tractor/loader thingy in your group photo as well
