Question regarding coatings on S.S balls?
mprozycki
Hello fellow enthusiasts,
I've been trying to reverse engineer some ball-socket joint designs using 360 fusion. I purchased these joints from John Wright model maker in the U.K. I'm doing this for personal use as I am a fan of stop-motion animation.
The current joint I'm studying is made of stainless steel plates with a coated stainless steel ball. I also have a previous version that was made from mild steel and a 304 stainless steel ball (no coating). You can see both in the attached pic.
I just would like to find out more information on the coating used with the new joint design?
I'm assuming it's TiC to help improve mechanical function. I've read that these coatings help with lubrication and wear, among other things.
If someone knows a bit more about this sort of process, please fell free to share. Thank you.
Cant help you on the ball but I'm curious about the seat surface under the ball surface. Is it a simple chamfer or..?
Is the general idea you want a certain amount of sticking tension so you can make a slight movement to an arm in the ball & it stays put? The screw is to set that tension?
mprozycki
Its a seat made with a ball-end mill. Like a chamfer but with a curved profile. You could just use a hole and a chamfer would develop over time with wear.
That's the idea. You have soldered pins that allow you to adjust the balls position and the screw tension keeps the ball in its place.
mprozycki
Yeah, John Wright has been around for some time. I've always viewed his work as a industry standard. Not to mention these joints are wonderful when they're assembled into an armature.
