Spring 2024 meetup in Calgary - date Saturday, April 20/2024. discussion Please RSVP Here to confirm and get your invitation and the location details. RSVP NOW so organizers can plan to get sufficient food etc. One week to go! More info and agenda
We are having email/registration problems again. Diagnosis is underway. New users sorry if you are having trouble getting registered. We are exploring different options to get registered. Contact the forum via another member or on facebook if you're stuck. Update -> we think it is fixed. Let us know if not.
Spring meet up in Ontario, April 6/2024. NEW LOCATION See Post #31 Discussion AND THE
NEW LOCATION
I decided to try using the fine cut consumables for my hypertherm powermax 45xp to cut out a decorative plate that I plan to use to build a coffee table. the cutts turn out beautiful if you see what could be tuned a bit more from the cut charts.
the diameter is 2ft, but the thickness is only 16 gauge, which is why I had to use the fine cutting consumables. I first intended to cut it at 18 inches in diameter but the tool paths created by both fusion 360 and sheet cam were not very solid, many details were open contours made up of multiple small cuts because the sizes of some details were too small.
I decided to change the design for my table to make it more unique and add more strength to the table top by adding a backing plate to the cutt design and running a decorative shaped rod up the legs and through the top with a forged metal rose on the end. I also improved the look of the legs from my original design.
I also realy like the extra applications the powermax 45xp gives you. The marking consumables allow you to use the plasma cutter for engraving as well, which is very useful for adding extra creativity into different projects like this sign I recently built.
After going over it with a medium flap disc I use a foam polishing disc like the ones sold here https://www.amazon.ca/gp/product/B07KC71TYT/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1. The foam polishing disc conditions the surface of the steel very well for the final polish which is done with a felt or wool polishing disc using white and green polishing compound. after the polishing is done I usually put a finishing coat of clear rustoleum spray paint.
