They are difficult to find as no one hands them out anymore, it was always faster than a digital calculator or control software.Man that looks like appropriate technology for me. I've been playing around with machining calculator apps and I'd prefer that one so far over the app style.
About 25 years ago I got introduced to an old machinist, tool and die type (whom I learnt a lot from), the first was discard the old feeds and speeds with current cutters, he was running speeds that initially shocked me. Basically what he said was crank up the rpm, increase the feed rate and use cooling. I haven't looked back since.
These older tools and tables are a good safe take off point though,
Trusty reference tool ,or just to confuse your customers who likely do not know what a slide rule is.View attachment 31085
Ha I was going to ask the same but I assumed I was missing something obvious and didn't want to be redundant or sound foolish (as I often do).@Stellrammer the name on your paper calculator is stellram… hmm coincidence? What is going on here?
Analog is seriously underrated in the digital age. It’s making a bit of a come back here and there. LP records. I love those paper slide calculators. I had one for car fuel mileage - where did it ever go?
I wanna be on your Christmas listOk, I want one. It look like I'm going to have to write the little bit of code to generate the slide rules and then print and fold. If that works, I'll laminate up a bunch for Christmas ;-)
The index style button insert that relied on the pin was a European thing forced on the North American market, it was not conducive to business in the Mould and Die industry. IIRC that was a late development though, 2006? I strongly objected but was overruled. However it was well accepted in the turbine industry milling heat resistant materials.I'm sure some guys here know,
Stellram had some good stuff out in the mid 90's. They went downhill fast when they switched to the index style inserts on the button cutter shell mills.
I knocked the pin out of the holder due to cracking of the inserts, however, the inserts still wouldn't stand up to anything we threw at them after the changes.
Many, stopped using them at the time and switched to Ingersoll, Mitsubishi, Die Jet and the like.
MarketHeck, you could smoke a Mitsubishi holder back then and they would replace it at no cost if you recall?
Oh, the printed money was good back then lol...
