My lead screw on my lathe is 16tpi so very small engagement spots for the half nut. There are 64 different spots on the dial that the half nut could engage but only 8 marked useful ones. On the little original small dial that means it's a bit hard to see if you are on spot or not. The difference between one engagement spot and the next is only about a lines width.
So I figured a larger dial would be one way to make the engagement spots a little easier to see.
I had nice fine indicator lines marked out but then went and painted them in to show up a bit better and now they look a bit crude.
I also never really cared for the indicator on the dial, plus the old one would not have worked with the new larger dial anyhow.
The larger dial makes the indicated marks come around faster but it is easier to see if I am on spot or not.
The jury is still out if it's a clear win or not. Right now, I think it's better.
