Try a machine shop or you could even Call metal supermarket they would probably cut it for a fee.
See what it takes to cut that cast iron - our 7" on the ship wouldn't touch it without a lot of force, a special hard material chop saw blade took me 1/2 hour for 2". The boys at the base with the hydraulic "set it and forget it" band saw was the answer.... it is hard stuff to saw.
I'd clamp it between the flat ends if you can, much more contact area than the 2 tangent lines of the diameter
Do you have power feed Craig?
