Milling Half Cylinders into Stock.
Alexander
It would be easier on the machine if you stick the bar stock out the side of the vice. Use a center cutting endmill and plunge about half of it into the part. First lock the quill and then move the table up. You need a rigid setup for this operation because only half of the endmill is in the cut. If you don't have a knee mill I would try using a ballnose endmill and mill across the part in a few cuts. That's just what I would try. There are many ways to achieve that feature.
Alexander
Please take a picture of it setup on your mill. I'd love to learn more about the machining capabilities of your mini mill.
kylemp
A 5C collet block would probably be best, especially if you are doing multiples. If not, you need to clamp them and come down at it and use the side flutes to cut.. just make sure you allow for a finishing pass and if you can you should probably be climb milling. Be careful about the stick out though as I imagine that you will end up with a lot of deflection without a tailstock set up.
Jwest7788
Joshua West
I'm planning on moving forward with this project tonight. @Janger was kind enough to show me his shop and help me cut up some steel to manageable sizes over the weekend. Now I have appropriately sized peices to work with. :D
Will be sure to take lots of pics of the setup and success/failure (haha)
JW
jbrownslms
I have used ball nose burrs from a die grinder with the same efect as a ball nose end mill, just slower feed, less depth of cut and faster rpm.
Alexander
I would like to see the ball bur in action on a milling machine. That is a neat idea. Might be pretty handy on a CNC Mill for rounding off edges.
Jwest7788
Joshua West
Agreed, it's not something I would have considered. I did read the other day about using wood router bits in a milling machine / lathe to some success (They commonly have carbide cutting edges from what I hear)
Jwest7788
Joshua West
First plunge cut went well. My oversize milling vise did a good job of work holding.
Will post full project pics in a bit here.
JW
