Redneck_Sophistication
When I bought my machines from the millwright who owned them hadn’t got a motor for the McDougall 16x30.
He did have a motor for an all gear drill press he suggested could be used in conjunction with a gear box he had. I didn’t ask why not to run it on its own, not sure what his long term plan was.
What size motor would you guys run? Original plate said 3hp, would that still be good or underpowered fir a lathe this size? Don’t want this ball less if I do some big stuff.
should I worry about Rpms? Or is most motors in the same range?
Next I’ll have to figure single phase or 3 and a VFD, I thought I could find a 3ph cheap from someone swapping for single but there’s not much on kijiji, probably all in the scrap yard. I saw so many there my last trip
