I've watched a few videos but none of the methods I saw seemed applicable to this center. There is a cap that threads on (not shown) and I assume that was used to press the assembly in place. On the tail end there was a tiny (#10-24) set screw that I think was just a place to insert lube. I tried to pull the live center apart by clamping the center shaft in the three jaw chuck (wrapped in aluminum to protect shaft) and then retract it with the tailstock. No luck.
Any suggestions?
Any suggestions?
