Lathe table wheels
I bought some wheels for my lathe table from caster land. I just called them and said I had a 500lb table and needed some wheels. They said you should buy these ones and I said well ok. $25 for a 3” wheel that’s nuts John. BUT! They are great! This is now the easiest and best rolling tool in the shop by far despite being pretty heavy. Also the wheels lock in both dimensions with these locking teeth and gear setup. What I’m trying to say is the wheel locks as usual but the vertical axle also locks. So the table is surprisingly stable when the locks are engaged. Best money I’ve spent in a while. Part # CCEP3125UNSPBTB
Nice wheels. Are the black levers the lock? What do you mean they lock in both dimensions? Like you can lock them to roll only in its set orientation & also lock them from rolling entirely?
So the black wheel lock lever locks the wheel from rolling as usual. But also the red highlighted teeth lock the wheel from rotating around the yellow highlighted axis. Parallel to the table leg. Those teeth engage at the same time as the wheel lock - clever mechanism. So the table is much steadier as the wheels can’t shift around.
So this style of wheel is apparently called Total Lock and they seem to have lots of different sizes etc on their web site.
#8
My mobile hobby lathe bench built September of 2007 sits on a similar set-up using six (180 lb load) rubber casters with the 4 end casters locking out all movement.
Great minds think alike! Bill
They have similar locking casters at Princess Auto as well. Can't speak to the load rating however. I have used several 4" ones and a set of 5" for various mobile stands in my garage.
