Stumbled on this video. Aside from the dismantle & replacement of a sprung ABL nut assembly, ~11:30 shows some other interesting arrangements used on other lathes.
Both screw and nuts were rather heavily worn (in the middle 3" of the screw especially) on mine. 3/4" acme thread (new) has a flat top crest of ~ .050". The mid section of the leadscrew was worn to the point that there is no more flat, they are now pointed - out on the ends, it looks almost as new. Female threads in the brass blocks are all worn to a point (flat totally worn away)." I was never clear what wears predominantly, the bronze nut, the screw, or both. I think I'm hearing it may well be possible the screw can wear in its predominant usage range."
Only thing I'm a bit disappointed in is a bit more turning resistance than I'd like and I think that's probably because I put "Moly-slip" grease on the leadscrew rather than oil - maybe just oil next time.
My 13" South Bend started off as a miss-purchased spindle thread protector from several years ago... Finally found a 1929 lathe to fit it and some collets I had. Strange how life goes.Almost time to do something about this one
It's from a lathe I had briefly decades ago. A standard modern. Almost unbelievably, more decades earlier, while a teenager in high school, I squirrel away a feedscrew and nut from an SM when the HS shop was changing over to metric. That feedscrew survived numerous moves, marriage and kids, as well as the odd purge but was right where I knew it would be,. And.....it was from the exact same SM model!! Plug and play. That sort of tale can create a 1000 hoarders...better keep this random part from some random machine at a young age when you never even imaged having your own machines....never know when you might need it
Think I'm gonna pull it apart again and wash all that grease off - might just leave it dry- agree with Mcgyver's comment about swarf / oil / grease making a nasty lapping paste.Mine has a ball oiler above it. Yours prolly has a lube provision of some kind too. Grease is usually better than oil for such things but no way to keep refreshing the grease other than adding a zirc or something. Might be better to remove the grease and keep oiling it.
The point of a system like this is you want just enough pressure to stop play, yes it wears but even if you leave play in the system you will have wear, the same amount.That guy is working very hard on his carpal tunnel case, poor guy. Folks, please don't use your hand as a hammer, you'll live to regret it.
My DSG corss slide has an anti backlash arrangement, as per photo. Never fully got what the point of it is on a lathe, and I leave it with some clearance else it just encourages more rapid wear
