Johnford vmc 550
PatrickJay3
New Member
We just bought this used cnc mill (JohnFord VMC 550) and wondering what should the level (psi) of compressed air coming into this machine ?
And how do we change tool in mdi ?
If you want meaningful help, you are gunna have to give us a lot more info than that! Most of us are hobby machinists, not mind readers.
Project Description?
Software?
Relevant tooling available?
Tooling being used?
Operator Skillset?
Lots of Pictures?
Found this on the web
I just hate that scrib d site. omg it's annoying.
and yes we'd love to see some pictures and detail sof the new machine.
I just download whatever it is I'm looking for and never deal with the site.
Yeah, more info. That will depend on your controller. It should be in the manual. The tool change instruction is probably an M code (likely M6).
So you’d send it T6 M6 ;
For a DX32 machine you need the semicolon. For an A2100 machine the semicolon is optional (unless you are adding comments). On the A2100 you can specify going to a predefined location before doing the tool change - then it is M6.1
You do have the manuals, right? I’m probably just a slow learner, but after going through the manuals over, and over, and over - plus a lot of trial & error testing of every line one can get good results.
Air pressure? That depends. It should say in the manual. There should be an onboard pressure regulator. It is probably going to depend on what the air is being used for. On my mill the air is used for an air purge on the main spindle seal - that is regulated down pretty low (~15 psi?), but the regulator feeding the tool change cylinder is higher (like 90 psi). The mill has an alarm and safe shut down (more of an interrupt) if the air press drops off. Can you just set it a bit above the alarm point? On the lathe the air is only used to purge the X axis scale, it uses 90 psi air, then a very small orifice to get down to a reasonable purge volume (and no alarm, so I kick myself when I forget to put the air on).
Like Susq says, need more information.
Compressed air is blown over the spindle taper during tool changes to blow off any chips. The air must be 'dry' as the seals on the spindle can absorb water and fail. (Or cause rust eeek) I think this is overlooked frequently on used machines. What is dry exactly? Nobody has been able to tell me quantitatively what dry air is. In Europe there are quantitative standards for dry and clean air but here? So I have a a desiccant bead style air dryer on the inlet line to the machine and I check it when I turn on the machine, but I live on prairie where it is generally dry all the time. Other people have a refrigeration type air dryer. If it's humid where you live then I would get a refrigeration air dryer. I need 90psi on the inlet. Gotta run and go make chips.
