Chicken lights
Forum Pony Express Driver
I was using these small steel drums to store extra chains and binders. Problem is once you get a couple hundred pounds in them they’re awkward to move
Black drum dolly- pretty light weight yet it fits the drum size nicely. Problem is where it’s bolted together is flimsy and wants to collapse, making it hard to wheel around. Simple solution is a circle of steel plate, drill a few holes and bolt it in place.
Green drum dolly- too large, but very heavy duty. Only issue with it is the chains, if hung on the outside, will drag and get hung up. So, do I get another circle cut out and use it as a floor?
Plywood and a jigsaw is probably cheapest and would work, too. Although I don’t think I have a jigsaw anymore.
I’m just thinking out loud here for the moment.
