I bought the cheapest Y axis power feed I could find for my milling machine.
I think that is identical to one I bought of Amazon. I paid $245 for it and thought that was a good deal. I now see that Amazon has it for $215. I'd say you did very well.
John Conroy
member
I mounted the travel stop switch to the same bracket as the Y axis DRO scale. The tracks are mounted with four M5 screws, holes drilled and tapped in the knee. Nothing about this in the instructions but if you have done one of these before the hardware is good.
The instruction manual is skimpy to say the least.
DavidR8
Scrap maker
Too bad they don’t seem to carry drives for RF30 style mills.
John Conroy
member
it might be a fun project to adapt a cheap bridgeport style one to fit. you would have to fabricate a bearing/support block and shaft extension but I think it's doable.
DavidR8
Scrap maker
So this gear/dog combo engages the small drive gear in the unit.
If I'm not mistaken, on the version that John has, the small drive gear engages a bevel gear on the shaft of the mill.
I'm very confident that the guts of the two units are identical.
I think it would be pretty simple to make the pictured gear/dog and the associated brackets.
@John Conroy did you take any photos of the drive end of the unit before it went on?
John Conroy
member
OK, you would need a bracket/support/bearing block to bolt to the table on the mill and support the drive with the center hole aligned with the x axis lead screw. like the black piece in this pic.
The small pinion in this pic drives the bronze bevel gear supplied in the kit.
the support bearing in the drive unit runs on this sleeve to keep it centered on the shaft
The shaft needs to be extended so you can still have a hand wheel. Shaft extension show here.
The bronze gear drives the shaft through a key.
Shims are used to control the backlash between the 2 gears.
The key in the extension shaft engages the handcrank.
I don't know what the end of the lead screw looks like on an RF mill. Maybe it would be too difficult to extend the shaft through the drive. If it can be extended you would need to make 3 main parts. The adapter block to attach the drive to the mill table. The shaft extension and the sleeve that fits into the drive unit bearing and slides over the shaft.
John Conroy
member
Judging by these 2 pics there are no threads on the ends of the lead screw to easily attach a shaft extension but the shaft could be removed and threads added in a lathe.
DavidR8
Scrap maker
I strikes me that if a block were added to the right end of the table, it could be made to work.
Pondering...
DavidR8
Scrap maker
I thought you got all the bits and pieces together to build one? I've been waiting to see your build:(
I’m curious about the left side handle on yours Craig.
How much past the end of the table does the lead screw project?
Both ends of the screw measure 17mm in dia.
The left side projects 60mm out from the mounting bracket and the bracket is 15mm thick.
The right side projects 80mm out from the mounting bracket and the bracket again is 15mm thick.
If that makes any sense...….
