Muddyboots
Spent a bit of time helping out at a machine shop, and am in the market for my first lathe. Thinking a southbend 9 or something similar with lots of tooling. Not in a big rush. It's just for the tool room in the farm shop.
Welcome from Lillooet BC. Finding a decent lathe is one thing, lots of tooling seems to come later. Sometimes lots of tooling included looks good on the surface, but if you aren't into the same type of machining as the previous owner, much of the tooling may be of little value to you......Spent a bit of time helping out at a machine shop, and am in the market for my first lathe. Thinking a southbend 9 or something similar with lots of tooling. Not in a big rush. It's just for the tool room in the farm shop.
Thanks. I was also worrying that they are trying to make up for something wrong with the machine. I see an inordinate number of 5 gallon overhauls, numerous sitting in a new home garage without signs of use. I'm hesitant to buy, if it can't be started first. I've bought a lot of crap, and am a little shy now.Welcome from Lillooet BC. Finding a decent lathe is one thing, lots of tooling seems to come later. Sometimes lots of tooling included looks good on the surface, but if you aren't into the same type of machining as the previous owner, much of the tooling may be of little value to you......
Thank youWelcome from Sherwood park.
Thanks for making me feel at home hereWelcome from Peterborough Ont.!
Thanks Hruul, it's great to be hereWelcome from SK.
Thanks, haahaaha. I heard you Winnipegers found a work-around for that. Once it's frozen, you can plow it whichever direction you want it to flow.Welcome from Winnipeg, where it’s so flat that rain water is confused to which way to run.
Thanks for the advice 140mower. I'll take any given, gladWelcome from Lillooet BC. Finding a decent lathe is one thing, lots of tooling seems to come later. Sometimes lots of tooling included looks good on the surface, but if you aren't into the same type of machining as the previous owner, much of the tooling may be of little value to you......
Welcome from SK
Thanks Dabbler. I feel warm and fuzzy all overwelcome from Calgary
Thank you, whydontu. I appreciate itwelcome from Vancouver
