Tool Fast shipping of reamer
Tool
jcdammeyer
John
Ordered this on the 19th of September. Arrived today. Sometimes things go really quickly. Other times not so much.
BTW, the "Drill Force" reamers aren't the best by any means. I think the sharpening job could be cleaner. But this one with shipping was $10.65.
15mm machine reamer?
Hand reamer I believe. Has a square end and a taper at the start. So not good for non-through holes.
I've used them on the lathe by using the center in the tailstock on the hole in the end, a crescent wrench on the flats and lathe turning very slowly.
Here's a photo of the one that just arrived. Maybe that will help?
The hole finish is no worse than with a boring tool.
Look like standard ali stuff - you got lucky on speed there!
Lately most of my Ali purchases seem to be coming more quickly than a few years ago. They seem to be shipping from China to a service in Canada (via Air Cargo container??) where the items are combined, re-packaged and sent out via CanadaPost. Nowadays I often get a plastic bag with items from several Ali sellers inside.
I've also gotten a couple of 'Full refund with no item return' results from disputes about bad quality items, so it's not completely hopeless if things 'go wrong'.
Still, it's a case of 'Don't gamble more than you can afford to lose" for me. a.k.a. "Don't sweat the small stuff". :)
Re: 15mm reamer. I hadn't done much work with metric sizing and fasteners until this year. It's been a pleasant surprise to find reasonable quality stuff at inexpensive prices from Ali (and occasionally Banggood), but pretty much only in metric sizing as far as I've been able to see. I have a bunch of Ali reamers and they seem to be OK for the rough sort of work I do as a beginner. I'm too cheap to buy $$ 'inch' reamers, so it looks like metric is the economical way to go, if that's an option.
