If you hate drilling like I hate drilling—HAVE I GOT A DEAL FOR YOU (almost 60% off in fact).
Bought this hydraulic ironworker at the end of 2017; it has about 50 hours of use. It has two workstations, one of which is a dedicated punch; the other is a Universal Open Station presently equipped with a Multi Shear attachment, but you can add other attachments. The Multishear does angle iron, round and square rod, as well as flat bar.
Included are 24 dies (rounds and oblongs), the 4-Way Bending Brake Attachment (never used) that can bend up to 7" x 1/4", the Gauging Table Kit (larger table w/ guides), and the Stripper Reducing Plate for thinner stock.
This machine will punch a 1" diameter hole in 5/16" A36 steel. It can accept larger dies, but material thickness will be thinner than 5/16"
This is the perfect machine for prototyping or smaller production runs.
Specs:
Rating: 25 Tons
1 HP 230 VAC
Stroke 1"
Throat Depth 5"
Open Height 8"
Shut Height 7"
Weight 1000 lbs.
See additional specs in images below.
Original cost was north of $12K with dies and included attachments. I am asking $5500.
It has a single lift point/eyelet for crane access. A narrow fork pallet jack would be required to roll to a crane or hydraulic lift at curbside. I am original owner and have all invoices and manuals.
Specs:
Rating: 25 Tons
1 HP 230 VAC
Stroke 1"
Throat Depth 5"
Open Height 8"
Shut Height 7"
Weight 1000 lbs.
