Cobalt End Mills
Alexander
Cobalt tools can deffinatly be run faster. Personally i think carbide endmills are definitely worth the money. I am still happy to use high speed cobalt drills for projects at home.
#3
Can you get small carbide tipped endmills? 1/4"-1/2"-1" etc? All the stuff I'm seeing is 2" or more.
Are you talking the ones described as "Solid Carbide End Mill"?
If I were buying I think I would go directly to solid carbide end mills. At least in the smaller sizes. I have two, 1/4 and 3/8 two flute. I bought them originally to do some machining on a rifle receiver They were not that expensive and I only use them on hard materials. HSS works for the rest.
Alexander
Yes solid carbide endmills are commonly in stock in all sizes from .063"-1." from manufacturers like harvey tools, kanametal, sandvik, widia hanita, and iscar. These tools are popular because they save time when machining when compaired to hss or highspeed cobalt.
#6
I guess I view this somewhat differently. I realize that labour cost is a big expense in modern commercial machining and tooling that is fast and efficient is essential. As a hobbyist I look for the minimum that will do the job and that I can afford. My time costs me nothing. To that end I'm phasing out all my carbide insert tooling in favor of HSS and Brazed Carbide. An hour grinding a lathe bit is time well spent. CHEERS
#7
Lathe tooling and drill bits I can deal with. End Mills not so much. I just discovered that most if not all of my end mills are toast. Wondering if stepping up to cobalt or carbide is worth while.
#8
Just for curiosity I did a look up on KBC. 3/8 4 Flute end mill. KBC branded. HSS $11.10, Cobalt $21.88, Solid Carbide $24.88. I've only ever used cobalt drill bits and carbide end mills a few times. I'd say the carbide is the toughest. I guess it comes down to budget, time and what type of materials you work on?
Alexander
I took this picture to show the difference between these two drills. The right drill is HSS with a black oxide coating. I notice it comes sharpened with a 118 degree point. The left drill is Cobalt which is sharpened at 135 deg. I imagine they do this becuase when drilling harder materials the 135 deg grind is stronger.
Since we're talking about drill bits...
I got a few larger drill bits in an auction lot. Of those, the 3/4" and 1" drills are both really dull. They're also both 135º points. I will always be using a pilot hole with these drills and almost certainly using 118º drills to make that. Is the mismatch in angles a problem? When I resharpen the dull drills, should I try to convert them to 118º points? That's a lot of metal on the 1" drill!
Just noticed that the 1" is marked "P&N Australia". Wonder how it found its way to the GTA?!?
I would skip cobalt and go to carbide directly. They last a very long time. They take "speed" abuse well. You can run cobalt a bit faster then regular HSS but not much - like 10%. They are also a tiny step up in hardness. Essentially cobalt with even 8% is just a touch tougher HSS. Its no match for even uncoated carbide. It is totally outmatched by expensive coated carbide.
Note there are grades - many of carbide - some are harder some are tougher - but even the "soft" carbide is usually rated for at least 35-45 HRS - so it will take care of any common annealed steel including 4330. It is simply not rated for hardened stuff.
I use cobalt drill bits a lot through. Have a lot of carbide ones as well, but cobalt drill bits seem to hold up much better then cobalt EM. Drilling in general is not as "intense" as milling. Also its easier to quickly sharpen drill bits - not so easy with EM.
"Just for curiosity I did a look up on KBC. 3/8 4 Flute end mill. KBC branded. HSS $11.10, Cobalt $21.88, Solid Carbide $24.88."
Wow there is a reason I never buy anything that cuts at KMS/ BB/ PA etc. Prices are outragous.
12mm solid coated TiAn end mill from China - new == 14CAD shipped (on sale). Works very well. If you don't care for sales get it for 17/18 CAD shipped. 10mm is a bit less - like 14CAD non-sale. The smaller sizes you see are more expensive as singles due to shipping costs included - just get more than 1.
You can get 1/2" US made carbide coated off ebay new for around 20 USD. I got uncoated 3/4" for under 30USD new wester made (I think Israel).
HSS 3/8 for 11 CAD??? Seriously? Who pays that kind of money? You can get brand new US HSS of eBay for around 3-4 pieces for 10 USD or so.
#16
I would not worry about change in angle - the whole point of a pilot is to drill it at least the size of the web on the larger drill so it doesn't have to "push" any metal. The pilot is just a hole - what made the whole is not very important.
Changing the angle will not hurt through - 135 is for harder stuff while 118 is general purpose. Other angles exist - like more > 135 for plastics.
BTW you can get a set of drill bits (5) at PA for $30 on sale - it goes from 9/16 to 1" and has 1/2" shank. I have used them a lot lately and they do work great in mild steel. The golden paint wears out quickly but what is under it seems like a solid M2.
I learned quite a few things from an old school tool and die maker. I don't want to seem contrary, but if you want holes that are true to size, you pilot with the same angle as the larger drill. This man has drilled and reamed many thousands of accurately sized holes, in precise locations for 60 odd years. If you can manage it, using the same angle pilot is always better.
How much better? well that is up for debate. The real difference is when people use a centre drill at 60 degrees and follow it with a 118 degree drill. A great way to dull the web, add heat and cut an oversized hole. The proper way to use a centre drill for following with another is to use the pilot section only, which is almost always at 118 degrees.
Look down a drill from the point end. The web is the little bit of steel that connect the two flutes of the drill.
When you pilot a hole there is no need to drill larger than the web, and drilling it much larger is counterproductive: the drill bites too fast and you risk breaking or chipping the drill.
