I have to make a couple of bushings which act as pilots for a reamer. The OD of the bushing has to be true with the ID. Usually, you can drill, bore or ream ID, then turn OD, all while in the lathe chuck....if you have a long enough piece of stock, and if its stiff enough to prevent chatter. In this case I took the 2" length pieces, chucked them in the collet chuck, drilled and reamed to 0.500". Then put the bushing into a mandrel and turned between centers. I have a bunch of dogs, but no dog driver. Usually, the three jaw chuck will act as the dog driver, but is currently indisposed at the moment, so I had to improvise. 2 muffler clamp bodies with the a couple bolts, and an elastic.
