Hi
Can a guy (or a Gal) build a base out of concrete?
Or cinder blocks?
Cheers & thanks.
Doog
Cinder blocks don't!
Concrete why?
Steel frame or heavy duty cabinet is more than enough. What you have is a mill is similar to mine, though mine came with a cabinet and chip catch.
Ask some one to weld you up a frame. Likely cheaper and more versatile as you and store stuff underneath it.
Blocks crack under vibration and will pull your anchors.
What about wood gents as an alternative? I know it is not recommended but... it's inexpensive, easy ? Perhaps using a lot of wood 4x4 screwed and glued together. Diagonal bracing..? My small machines are on wooden benches, occasionally I have to tighten the bolts.
Was just kicking the idea around
I have a bunch of cinder blocks on hand.
I welded a steel table for my Mill/Drill and it's not as rigid as I'd like. Could shore it up.
Steel is kind of expensive right now.
Cast Iron is the ultimate i think.
The factory stands seems a little light unless you stumble upon an old school one.
I have a wooden lathe bench (12 x 36)....works lovely but wood is thru the roof even though our Canada is loaded...lol
I have an idea on how to clamp the blocks together so that I coul dismantle if moving. Would load the pockets with something.
I like sailor proof stuff.
The wee mill is a sit down jobbie right now.
Thanks
Doog
