Are gears with the same Diametral Pitch (DP) guranteed to mesh?
I'm looking for a 28 tooth mate for this 14 tooth gear.....
The DP appears to be 16. The only gears that match the required diameters on the McMaster-Car website are 16 DP 14.5 PA gears.
So is going with 16 DP 14.5 PA a safe bet?
I'm no expert but I think 14.5 pressure angle is an extremely common specification in dp gears. It is the only PA I've seen in dp gears and 20 PA in metric module gears.
Are you sure the gear is dp and not metric?
Not sure of anything. Gear is for my made in Ontario Peerless Tool Co. Shaper. It appears to mesh well with the 28 tooth head stock gear on my Utilathe but I never did establish what the parameters are for that one.
RobinHood
Another approximation is to use: DP=(N+2)/OD. From that it would appear that the gear you have has an OD of ~1” if the DP=16. Can you confirm that?
Gears with same DP should mesh. Based on the age of the shaper, it probably does have gears with 14.5* PA. I think 20* became more popular later as these gears supposedly run quieter.
Since this will be a low speed, low torque application, even if the PAs were different, it should still be fine.
I'm seeing 0.993" so very close to 1.0".
It's interesting that it was a 28 tooth gear I was missing for my Utilathe as well. That one I obtained from a parted out lathe so I never did figure out exactly what it was.
RobinHood
Yes, that would be nominal 1” => close enough.
So yes, if you see a gear on McMaster that is labelled DP = 16, it will mesh properly with your existing one.
If you can’t find a suitable gear online, I can make you a 28T, 16DP, 14.5*PA gear; I just checked, I have the correct involute cutter.
Brent H
Ditto for me @RobinHood
I am looking to buy a set of 20 PA tooth profile gauges so I can verify some gears I would like to make.
The Utilathe is a combination of 20 and 14.5 PA
These are what I'm replacing.....
They are the power feed drive gears. The driving gear is 27 tooth, 1.45" OD with a 3/4" bore. The driven gear is 25 tooth, 1.346" OD with a 1/2" bore. They are being replaced with a 28 tooth, 1.88" OD gear and a 14 tooth, 1" OD gear.
Quite the discrepancy eh???? That's almost twice the feed rate. I wonder if it was geared down for a reason?
@francist can you comment on this?
Brent H
Perhaps they came with two sets of gears?
To be spot on, if it is just those 2 gears in play, remake both with the 14.5 PA and there is no issue.
No, what's installed are the wrong gears. The gear depicted in my OP is meant to be moved between the horizontal and vertical feed shafts. The gears installed are the wrong diameter such that the movable gear is captured and you have to disassemble the power feed ratchet mechanism to switch the driven gear between shafts.
francist
Huh, no idea. If I’m getting this right the existing arrangement presents a lower gear ratio resulting in a slower or smaller increment in the table movement? I don’t know why you would need that unless to lessen the chances of burying a cutter during a cut. I confess I don’t use the vertical feed on my machine, only the horizontal, but I can see if you’re trying to sneak up on something like a keyway depth it’s real easy to have that relatively wide cutting edge grab and bury itself. A smaller increment might make that less likely.
That’s the only thing I can think of other than pure chance that those gears are the only ones they had on hand and they decided to use them. One looks like it may be an old Atlas change gear, it has the two opposing keyways, but their gears weren’t steel.
-frank
Mcgyver
If you've tried this and it worked, I bow to your experience, however I'm thinking it would be a problem. For sure a 14.5 or 20 dp gauge shows a significant difference in fit when you try gauging a gear - the correct PA drops in a lot farther than the incorrect. If on a banjo or something it might work but would be rough runnng....if its a fixed distance I'd be betting they wouldn't mesh.
Can you tell from your cutter and the gear I have if it is in fact 14.5 PA?
RobinHood
I have a gear pitch gage. It is for 14.5* PA. The cutters are labelled with ”14.5* PA”. We could check the little 14T gear you have.
francist
Interesting. I just took a peek into Machinery’s Handbook because I was rembering they had a full-size layout of a bunch of different gear teeth. They do, but they don’t say what pressure angle they are but in the text on the opposing page it went into why the 20 may be preferred over a 14-1/2 degree angle. One of the most striking reasons was the number of teeth — less than 18 teeth and the undercutting in the tooth form starts to become undesirable, and at 14 teeth is verging on excessive. So, the one small gear on the shaper is 14 teeth — I wonder which pressure angle it will actually measure out at? By the book one might think it should be 20.
-frank
