12VDC Double Acting Hydraulic Power Pack - FREE
CalgaryPT
I've had this unit for about 10 years. It looks dirty and dusty, but it has been inside my shop the entire time—I promise. It has only been used maybe a few dozen times, and that was 10 years ago when I bought it. Originally I had it on a hydraulic post puller I built for a friend so we could remove some massive posts on his property. I built a towable puller we attached to his ATV. The unit and all components are from Princess Auto, and it is similar to this model: https://www.princessauto.com/en/12v-dc-double-acting-hydraulic-power-unit/product/PA0008652596
It has a 1.5" x 12" stroke cylinder on it and 6' hoses (1/4") with quick connects, as well as a couple of extension hoses. I also added a good quality gauge. Everything is in great condition, including the hoses. All in, it's probably $500 - $600 new with hoses, gauge, cylinder, etc. Should work great (although I haven't run in almost ten years.) Either way, easy to get replacement parts from PA if ever needed.
Free to a forum member who wants it. I'd prefer if you want it for yourself to use rather than resell, but that is not a condition of the deal.
Suitable for scissors lift, dump truck, etc. If you intend to use it standalone (as opposed to on a vehicle), use it with a deep cycle battery such as marine or Optima battery, otherwise you'll drain it and damage your AGM battery. You could use it for a big press brake if you really wanted, but it would be overkill as you don't need double acting, and you'd need a battery.
If you are in Calgary area I will deliver, but it will have to be curbside due to Covid. PM me if you are interested.
Oh all sorts of fun things a person could make with that. I always wished to make a dumping box on a 5x8 trailer and one of those things would be just right.
I better clarify...I dont have any immediate plans of making a dumping trailer anytime soon so I am NOT asking for it....I'm sure someone more suitable will be happy to take.
CalgaryPT
If it is still available I’ll take it and make a donation to the site.
It's all yours then Tom. Send me your address and info in a PM, and a time that works for you. I'll get it cleaned up and drop it off.
