My four position tool holder on the CX701 from busy bee has a number of problems. The main problem is it slips and rotates counter clockwise under heavy load for example when parting off. Tom's practical machining video on parting says an essential requirement for successful parting off is a very firm tool holder in a QCTP. The four position tool holder is also annoying to adjust as changes in angle require a wrench and adjusting two bolts.
Ok, I'd like something better so what to buy? At the top end are some fancy 40 position Swiss tool posts which cost more than the lathe! No matter how much money you've got you can spend a lot more with this hobby...
Busybee does not have anything they strongly suggest as anything they sell requires mod's for this particular lathe in order to mount it. KMS has a couple of options, again I think mods will be required to mount it. Both are the piston style. Research shows a wedge style post is firmer and more accurate, a little more money too. Another hobby machinist suggested one from the Canadian firm Accusizetools.com. It is $238 plus shipping.
http://www.accusizetools.com/quick-...-sets/?page_context=category&faceted_search=0
It looks pretty good. Anybody using it?
Another problem I see is the hole in the carriage where you might mount the post is actually quite far from the end of the carriage. The tools may actually be hard to get into position with the work material. I suspect a new hole needs to be drilled.
Comments... thoughts?
